I have removed and taken the engine aprt now and I am going to replace the cam bearing and crank shaft bearing. The question is do I just order std bearing or do i really have to look at the table and order the correct stuff? I mean the table even has std 1,2,3,4,5.... made you think there are 5 set of std bearing, wtf?
O one more question, do you guys usually replace your valves? I took them out to replace the oil seal and the intake one is still ok but the exh one has deposit on them and i put them in the dip chemical to get the stuff off. Should I just replace the valve or just scrape off the deposit with a sharp blade after dipping them in the chemical to loosen them up?
lol actually I got a couple more questions.
Since I removed the engine and figured I got blown piston ring and there are carbon deposit inside the intake manifold and intake valve area, I tried to use a drill and clean them off with metal brush. Do you guys know of any better way of remove the stuff, especially when it come to the manifold since I don't think the drill will reach that far in. I was thinking of getting a tub and dump immerse the head and manifold in gasoline and cover up the tub and let it soak for a couple of day and hope the carbon come off after using high pressure water compressor.
