Got a Lemons car in the works. It doesnt have to be fast, it only has to survive for two days.
I have the 7MGE motor taken apart and it's time to do rings and bearings and gaskets, etc.
There are Ebay kits all over the place for mains and rod bearings, gasket kits, even some that have everything up to and including pistons. I have always been an OEM guy when it comes to mechanicals but the difference here is I am NOT trying to enhance performance and I'm definitely not trying to get another 100k out of this motor. All I need it to do is last about 1000 miles without hemorraging.
That said, the Ebay kits are typically 100-150. A teammate has a relative working at O'Reilly's and rings, bearings and gaskets from them would be ~$400. A reliable engine shop quoted 170 just for the OEM rings, God knows what everything else would run...
The trick is not spending a ton on a car that might get wiped out 2 laps into the race but not going so cheap as to end up with unuseable junk.
Opinions? Aftermarket alternatives anyone has used? Things to avoid?
