bc ti retainers/bc dual valve spring with a stock keeper
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i finshed installing my bc hardware stock vavles but i was missing 2 stock keeper's so i used 2 brand new toyota ones on the intake side since it has the less heat
so i looked at them close tested then on vavle and they help tight
they look the same as in taper as well
but the bc ones looks harder then the toyota ones as in better quilty vs stock
so what should i do i don't wana drop a vavle but it should work ?????????
Are you 100% sure the taper is correct?
From memory Ferrea use a different angle not sure on BC as I haven't used his hardware, unless you're using retardedly stiff springs a stock collet won't fail.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
dual vavle springs
i like took the retainer and the keep put them on the vavle can it slight tug and it locked and binded up pretty good ??????
i know some have diffent taper thus why kinda ummm not sure the eye ball can be off
i think the best bet is to call them and ask
better then dropping a vavle i must say
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well i just called them and they said it would be fine but he was very fast to say yes
still conseres me hummmm all call them later i trust no one when they asnwer that quick
gaboonviper85
3,236
Northeast Philly
If you are that stressed over it then wouldn't it make sense to buy upgraded keepers for peace of mind?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well i lost one
and going to call them again tommrow just to make sure
head not being install any time soon i still have time
