Ok, so looks like form the PM's and the activity going on in this forum not everyone agrees with what is being presented.
SO lets talk.
#1 Upgrading your front breaks ONLY with a NON-ABS car will throw out your bias depending on what you are putting on, how much bigger how much more clamping force.
#2 Even on a ABS car you will need to lock the front's to trigger the abs before you can get maximum breaking form the rear which will require you to press the breaks even harder when the abs are pumping for you.
All front break upgrades like ARZ's, Dowards will do the above. You will need to match the rears to the front. Close to stock specs to achieve the same balance as stock OR you need stronger rears and a proportioning valve to adjust the rear's so it doesn't lock up first.
With the help of the community lets crunch some numbers.
I need the front Piston size. I already have the stock rears for mk3, and the PBR calipers. We also need the MK4 rears's and we can also look at the mk4 fronts.
So lets get cracking and lets talk.. We need unmolested unbiased opinions here.
SO lets talk.
