So I am in the middle of relocating my battery in my 89 na targa shell (2jzgte vvti swapped) but I have run into a few questions
First:
so i have ordered this switch and installed it and I'm starting to wire everything in, i was told to get this switch because i can also cut power to my alternator, only problem is with this one and also the moroso one (http://www.jegs.com/i/Moroso/710/74102/10002/-1) they both show a 20 amp max for the alternator plug, am i reading something or understanding this wrong? don't the 2j alternators put out like 75 or 90 amps?
http://www.taylorvertex.com/Support/pdfs/MANUAL-307113474.pdf
Second:
As stated in the NHRA general rule book the box must be mounted to the frame or frame structure, I'm wondering how people have mounted their boxes? I'm thinking of dropping the tank and mounting it almost over the fuel level sending unit access panel in the hatch.. Anything helps!
First:
Second:
