Battery keep losing juice...HELP??
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
So i had my car sat for the winter. I went out and try to fired her up just to let it sit there and run about 2 weeks a go. I would do that every 4-5 days. That day when i had the key in the gauges were on. However when i try to turn her on it would dim the lights and after couple of tries there was no juice left. So i guess there the battery is gone since i tried the stereo and it didnt work either.
So i recharged my battery and pop it back on 2 days later and it would fired up right away. I thought it was back to normal but about couple days after that i tried to fire her up and nothing was there; no door lights no gauges. NOTHING. And i have been doing this for the past week. Im not sure if theres a bad connection anywhere and i have checked possible places. No blowned fuses.
The battery is out right now recharging but i dont know where to start to look for possible answers. Please help, i want to run her again because it is getting warmer now. If theres anything missing please inform me. Any input is more than appreciated. Thanks
johnathan1
Supra =
Aug 19, 2005
5,056
You're using a lot of the battery's power everytime you start the car, and since you just let it sit and idle for a short period of time...it never recharges fully...so if you keep doing that, it WILL eventually die.
You don't need to run the car all the time, BTW.
Suprawannabe
meh... im lazy
Oct 27, 2005
122
Denver, CO
Your battery sound like it's on it's last leg. Get it load tested to see if it is bad. This can put a strain on your alternator so you might want to check that out as well while getting the battery tested.
akito
Jul 31, 2006
1,568
Springfield/Va
Well, this is wat i have right now, a 89 camry 2 piece tape player in there. I just bought PHOENIX6 head unit. Waiting for shipping. Would u think that the 89 camry stereo would do anything???
KeithH
Portland, OR
The MkIII will slowly drain the battery if you leave it sit. Get a battery tender (trickle charger) and leave that connected for those long (read more than a couple days) periods between starting.
akito
Jul 31, 2006
1,568
Springfield/Va
black87turbo said:
Check your alternator
I had thought about that but it doesnt seem that way. But i will get my alternater tested anyways. And the battery too. Hopefully there is not a bad connection anywhere. Thanks for all the input guys.
