battery cable
mk3-4-me
669
Milwaukee, WI
so can some one please tell me how many cables hook up to their pos terminal. I have 2, one to the starter and one that goes into the body wiring harness. I have 2 gounds to. The bigger one on the block cause thats where my buddy told me it should go, and the other smaller one screwed into the body. does that sound right? i have no power at all getting to the car after i put the motor back in. I got a new main fuse in the engine bay and still nothing. Idk what else to try.:: angry ::
DeadlyWrenches
Jan 9, 2010
24
CT
By the way you described them, your battery cables sound like they are connected properly. Are you sure the battery isn't dead? What is the battery voltage? I would be checking for proper voltage at the AM1 and AM2 fuses/fusible links in the fuse box that is located right next to the battery.
