Basic tune up
supraman7mgte
Shut up,bitch!!
Sunny California
What is required for a basic tune up?
I guess the normal replacement of spark plugs,but how often should the plug wires be replaced? Timing checked? Assorted crap need to be adjusted,and if so,what?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
for the supra... check timing, check for leaks vacuum and boost, replace spark plugs, check the wires to see if they ohm out properly, check out the air filter, replace or clean,
wait... and were you driving through tracy the other night ago? i think you were at a light, and i was in a red supra and you blew off on me. haha... hks bov?
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Change all fluids and filters
Replace worn vacuum hoses
Engine oil/filter- 3-6k depending on type
Fuel filter- 50k
Transmission fluid/filter- 30-40k
Power steering fluid- refill as needed
Brake pads/fluid 30-40k
coolant- 30k
Plugs- 60k
Plug Wires- 80k
timing belt- 80k
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
I would suggest you buy at least a haynes manual or equivalent(or a TSRM) before you undergo much work on the car.These will also have all the intervals, and items for scheduled maintenance in them
supraman7mgte
Shut up,bitch!!
Sunny California
na.was'nt me!
I know all the other stuff needs to be replaced like the oil and filter,but i talked to a tech a few months ago and he said some shops just replace the plugs and wires and call it a tune up.
I know mine is burning fuel,and was curious as to what might be suggested.
Perhaps timing and some other crap
