To be clear, I already had a 1PC driveshaft, and I am in no way interesting in going that route again.
Anyhow, my current driveshaft was acquired to replace the 1PC but has since developed a metallic squeaking noise at low speeds. Today, I replaced the carrier bearing hoping that was the issue, especially considering there was play in the older unit. After completing the job, much to my dismay, this did not fix the issue.
At this point, I am convinced it is the u-joints, well most likely just one (singular). The issue (stated in the title as well) is that these appear to be non-replaceable in design, which I have read about in the past on the forums.
My question is can I do anything to replace them? drilling the metal out? getting new ends welded on? I would really like to keep this shaft after all that has been done.
Thank you all for your time.
would this apply for the Supra shaft: http://www.rx7club.com/showthread.php?t=517657
