I've had this issue for awhile I bought a 3.73 LSD from another member here, he had to ship it dry. I originally put Castrol 80-90 (http://www.oreillyauto.com/site/c/d....oap?ck=Search_N2367_-1_-1&pt=N2367&ppt=C1985) in it. As I drove it the first time when turning the inner wheel always was locked up. So after a bottle in a half of motorcraft friction mod it's mostly gone. But in parking lots tight turns or loose gravel the inner wheel will still skipp about or leave tire marks on tar. I added another bottle (After draining some) and it got better but still definitely has this issue. The oil that came out was black and goopy thick.
Should I just drain and add lots more modifier maybe try redline's? Was the original oil bad and I should replace it with something else like 75W-140 since it already has the modifier applied? Or is this rear end just need servicing and clutches replaced?
