Just need to clear the air waves with this, what happens when the circuit-open relay goes bad? The car's behavior:aigo:
di_rosa;1043986 said:your car won't start. the COR turns on the fuel pump relay and thereby the fuel pump, so if it goes bad, no fuel pump, and therefore no start. a lot of people (including me) have just bypassed this relay. it is meant to only turn the fuel pump on when the car is actually cranking over, hence why it takes a couple of turns to actually start instead of just 1.
if you hear your fuel pump (after cranking), then it's fine. by bypassing it, it just means your fuel pump is on when your key is in the "on" position. nothing else as far as i know
honestabe;1044002 said:I've done the bypass so that I've manually turned on the fuel pump my jumping it at the diagnostic port and the car still has the same issue.
di_rosa;1044003 said:well, according to the wiring diagrams i've looked it seems that if you pull the relay out, the fuel pump relay will not have power, and therefore won't turn the fuel pump on, so if that is possible, then yeah, the relay can fail and not turn it on..........but shutting off while running, i dunno, that's weird.
it might be easier to just bypass the relay like i was saying, and see if the problem goes away?
THE1JZSPECIAL;1044016 said:ok I was bypassing it but with the relay off, i haven't tried with the relay on
di_rosa;1044025 said:what do you mean with the relay off? i assume you pulled the COR and put in a thick gauge piece of wire to jump it and then try to start it?
do either of you know for sure that you have stable fuel pressure from like a gauge? do you hear your fuel pump all through the cranking?
have you checked for codes? spark?
di_rosa;1044036 said:oh, ok, i bypassed mine more permanently by leaving that 10gauge wire in the relay plug.
so what happened when you did that? did you hear the fuel pump come on and stay on? if so, then my guess would be either the injectors aren't firing, the ecu, spark, or timing (cam/crank sensors, and valve timing)
check for codes
honestabe;1044049 said:I'm throwing codes 14 and 31, both of which point to the ECU.
honestabe;1044056 said:My other car, a 94 Geo Metro.
honestabe;1044056 said:My other car, a 94 Geo Metro. Total cars in my driveway between the 3 of us is 8, including 1 stubby trailer, 1 fully enclosed dragster trailer, and 1 dragster.
THE1JZSPECIAL;1044057 said:Now thats a car 35-40 miles to the gallon chillen all day, Im selling my dodge intrepid the thing is way to big I wanna get a 92-96 toyota camry or a geo prizm(corollas step brother) thier cheap I useto work for toyota and thoese
4fe, 5fe engines are superb
