Back Up light question
supraboymk3
99
Oakland Ca
Ok so im done with my 1jz 5speed swap i just wish i can get my back up lights to work. I dont know what wire to hook up were or what. Sorry i got a shop to do my swap. I would really want to get my reverse lights to work thought. dose anybody know how, originaly i had a 7mgte auto.
thanx
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
What trans do you have in it now? Every transmission has a reverse light switch in it, on it, or around it. Take a minute and look at the TSRM for the given trans that you have. The TSRM will have the diagram showing where the reverse light switch is. should be able to hook it up to the existing chassis harness, unless the shop removed that for you.
supraboymk3
99
Oakland Ca
Vrank!!!;1552608 said:
why didn't the shop that did the work hook em up?
I dont know I guess we never came to an agreement about that
---------- Post added at 02:24 PM ---------- Previous post was at 02:21 PM ----------
Its an r154, came with the 1j. I do see a wire on the side i just dont know were my harness wire that gose to the back up lights is at.
JonoTurbo
Going for broke
CT
It completely depends on how the shop wired the harness where the wires might be. I could tell you where they are in the glovebox, but from there out the shop could have wired them to anything. Also is the 1jz harness originally auto? If so, the wires are there but they are on a different plug.
The backup light switch connects to a two pin white connector on the transmission side of things, you should be able to find that under the car. Check below the intake manifold for a matching connector.
supraboymk3
99
Oakland Ca
the 1j was 5 speed. iv seen 2 wires on the passenger side of the tranny but they seam to go up into the car im not sure i need to lift it real good, see if then i can find were they go. ill check by the intake manifold.
thanx
xzeror
1,356
Miramar, FL
i asked this question but for my 7mge to my r154 they say its on the right passenger side, the plug. not sure where from the harness though. i tried to find it with no luck lol
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Alright, the passenger side of the trans is indeed the backup light switch. it has two wires coming from it. Red \ Black and is on the M1 Plug and the other is Positive for backup light switch Plus for Heater water valve VSV --------------- YELLOW BOTH are located on the M1 plug.. Hope this helps you..
if it does not go to my site these diagrams will help you!!
http://92tealsupra.webs.com/88turbomtwiring.htm
---------- Post added at 01:44 AM ---------- Previous post was at 01:43 AM ----------
Correct about where the plug is, it then runs into your glove box it is not hard.
supraboymk3
99
Oakland Ca
thanx that helps, so i just have to run the two wires from the tranny up to the M1 plug and then plug and play with wire 1 and 2 right?
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
That is correct.
