avc-r hardwire question
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Was wondering if someone who has an avc-r wired up or even sitting around could tell me which color wires connect to each other from the avc-r to the boost pressure sensor. For some reason my plug that goes from the avc-r to plug into the boost pressure sensor plug isn't there so I have to hard wire it...
Just need to know which wires go to which since they are different colors...
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
I will get that to you later today.....
Disced
Pie + NYQuil = FTW
Edmonds, Wa
ok cool... and i don't mean the diagram for the ecu ... i need the 3 wires that connect to the boost pressure sensor plug hardwire diagram...like to cut off the two sensors and then hardwire it...
Just to make sure.. =)
Gotta install this bitch today so I can finally run 18 lbs~
Disced
Pie + NYQuil = FTW
Edmonds, Wa
come on guys.. running out of daylight.. need to crank this shit up but can't cuz i can't wire up this gay sensor...lol
suprastanger507mgte
Hayward , Ca
Here you go. I hope this is what you were looking for,
Moe.
