AUTOmeter Sensor
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
I just bought an autometer auto temp gauge and i was wondering if i can use the stock temp sensor instead of the autometer one
reason being i cant find the fitting size that goes in the water neck hole so switch out the sensor
the Gauge itseld on the back says Ground, sensor,Ignition i ran the ground to the battery and the sensor wire to the stock Temp sensor and im not sure where to run the ignition wire
I am opening to an ideas about the fitting size for the temp sensor on the water neck and where to run the ignition wire for the gauge
gaboonviper85
3,236
Northeast Philly
ignition wire would be the red or yellow stereo wires (example)....its the one that doesnt get power unless you turn the key while the other one is always hot!
noel
Uchiha Member
May 5, 2008
512
this is for a 88T Supra
but which ignition wire should i splice? its really simple on the back of the gauge says ground, sensor, and ignition i got the groud and the sensor
Also can i use the OEm Temp Sensor or do i have to use the one that autoMeter gauge came with?? ....If not what size is the temp sensor cuz none of the fittings that the gauge came with fit. There either to big or too small
noel
Uchiha Member
May 5, 2008
512
oOo i c so i can use the red or yellow stereo wire for my ignition wire ?
