I need some tips and parts ill need for the swap, I will be running higher horsepower here in about a year or so, so I need to swap transmissions but I have no idea what sort of stuff ill need.
"5 sweep R-134" I think you mean 5 speed R154, R-134 is A/C refrigerent. Also there should be plenty of information on here on what youll need for parts.
There's quite a bit of info on this. Do some searching and I'm sure you'll find everything you need. I've done some researching on this too and the info is not hard to find. Here's a start http://www.cygnusx1.net/Supra/TechTips/r154_swap.aspx .
