you already have a stock one built into your radiator, but extra is always good, i am running a fairly big cooler on mine. One of the biggest destroyers for the A340E trans is heat.
i allway's ran a cooler on mine.i hook them up on the return line after the radiator.the fluid will travel through the radiator, then through the cooler on the way back to the trans
