Nick M said:
Or his throttle pressure is too high. That is adjustable. If you have recently been on the throttle body, and moved it, that is a possibility. Shift quality isnt affected really by the shift solenoids, only timing. Same with the TPS input.
The lock up solenoid is possible, but often the car will stall when trying to start off if the converter is locked.
Trust me, if the solenoids are clogged or non-op or leaking through the O-rings it will do exactly as suprastic describes i.e. hard late shifts.
TPS is a possibility for erratic or incorrect shift points but not likely to produce the symptoms described in this thread.
Read your own reply nick, "shift solenoids only affect timing"
what do you think a late shift is? :nono:
And as far as the lock-up solenoid goes, it is far more likely that if this solenoid goes bad the torque convertor will not lock up or lock up erratically rather then stay locked up which would cause the car to stall, but again, this isn't likely.
Also possible is stuck accumulator(s). If you find no codes (I doubt it) pull valve body and check accumulators.
Again, the first thing to do is check for codes so at least you have some kind of info to (hopefully) put you on the right track.
