should I use my jdm mt ecu or leave the auto ecu In it?
S Swifty New Member Jan 13, 2011 44 0 0 Minnesota Jan 31, 2011 #1 should I use my jdm mt ecu or leave the auto ecu In it? Last edited: Feb 2, 2011
nuggets New Member Apr 14, 2009 207 0 0 Boston Feb 3, 2011 #3 I tried both an auto ecu and mt ecu with my swap. Both worked fine. I'd only use the jdm ecu if you are running a jdm spec engine.
S Swifty New Member Jan 13, 2011 44 0 0 Minnesota Feb 3, 2011 #4 Did you still have to bypass the park neutral switch with the mt ecu?
nuggets New Member Apr 14, 2009 207 0 0 Boston Feb 3, 2011 #5 Swifty;1669698 said: Did you still have to bypass the park neutral switch with the mt ecu? Click to expand... yes, the park neutral switch is wired into the starter circuit.
bioskyline New Member Oct 21, 2010 1,236 0 0 powell river bc Feb 3, 2011 #6 if your still running the AT harness, you can jump the wires on the transmission plug for neutral start.
