Auto to manual. Pedal question
Sl!ck
60
Texas
Ok, I have an auto 88 supra. I'm trying to install the clutch pedal, problem is I don't know where to start. DO i need any special wiring? I looked but couldn't find a spot to bolt it too, should there be one or do i have to make one? Thanks for any help.
mkiiichip
1,434
WI
All the holes are there to bolt it right up.
Did you remove the little cover the master cyl is going to go through? just hold it up with this as a reference point and youll find the others.
Also removing the drivers seat makes this job much easier.
dsm_tuner260
138
Fort Wayne, Indiana
all bolt up. you have to remove the steering wheel unercover and in the black foam there is a small square peice that you need to remove its been precut just been to remove it. the plugs i didnt even bother with
