One switch will trigger as soon as you move the clutch.  That one goes to the cruise control, so that it turns it off as soon as you press the clutch pedal.  (Normally open, closes as soon as the clutch pedal moves.)
One switch will only trigger when the clutch is all the way to the floor.  This is for a neutral start switch.  (Normally open, closes when the clutch pedal is completely depressed.)
