Auto to 5spd swap from clip
Troyota
I Love What You Do For Me
Jul 28, 2005
243
Roswell NM
Does anybody know what extras I may need when making the swap from an Automatic to Manual using the 5spd equipment from my JDM clip?
Troyota
Jul 28, 2005
243
Roswell NM
Do you understand what I'm asking? I am going to Convert my N/A Auto Supra to a Twin Turbo 5spd using my front clip...I just need to know if everything in my clip will swap over to my LHD Supra or if I need to source any parts from a USDM Supra to make everything work correctly.
esc
WUM WUM!
Winston, NC
I would assume that the console for the shifter and everything won't be compatible since it's all setup for RHD. Might have to source a LHD center console for that one. I would assume everything else should bolt straight up though.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Don't forget to use the Boot that goes around the shifter or else you will get a lot of exhaust fumes in the car.
You will definitley need to change the brake pedal of that automatic ( too wide)
you will need the 5 speed s drive shaft as well.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
you may need to source clutch pedal,brake pedal,clutch cylinder w/hard line.alot of this stuff is lhd-rhd specific.i got all this stuff from a pic your parts junkyard for $40
eps
usa
I went from an N/A auto to a 1j 5 speed and used a lot of the stuff from my clip. The only thing I didn’t use was the clutch pedal. The brake pedal works, but not well. It hits the steering column about ¾ way depressed. The brake and clutch pedal are also only 1-2 inches apart now.
