Since the Auto NA transmission is supposed to be weaker, let me ask this.
With an electric fan + transmission cooler, will the NA Auto be able to handle 8-10 PSI, or is the tranny doomed and I have to get a built one or something?
If you have taken care of your supra, you can virtually do anything you feel like. I am quite sure that there are some fully automatic turbo's. There has to be. The stocker tranny should be more than capable of an n/a with 10psi of boost. Make sure that your head bolts and valve cover gaskets are torqued down.
should be fine, keep an eye on the auto oil if it gets that brown burnt look / smell its sliping... if you notice it slipping back the boost off a bit but i think it should be fine!
you may also want to look on supraforums at the auto trans shift firming mods..
