Auto Harness with Manual ECU??
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
I was wondering if the automatic 89+ Engine wiring harness can be used with the 89+ Manual ECU???
I did an auto to manual swap.
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
NO
You can not use a Manual harness on a Auto. It does work the other way around.
I did this on a 88 n/a manual i had using a 89 n/a auto ecu.
I don't know about a Turbo... but I'm 99.9999999999% sure you can't.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
NeatOman;1104390 said:
NO
You read wrong, its the other way around.
Can i use an auto harness with an manual ecu???
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
my mint condition auto harness i'm saving has pulgs for a manual or auto tranny. i can't say for sure, but i'm pretty sure it will work. i think mine is out of a 91. the motor that it was off had round mounts. i wouldn't just go off my word though. i'm sure there is someone that has tried it.
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
You can use an auto ECU and harness and switch to a manual trans. I don't see any reason why you couldn't use an auto harness with a manual ECU as well. The only issues are cruise control wiring, clutch safety switch, and back up lights that I've run into. I did this with an auto ECU and the car seems to run fine. Still haven't configured the cruise wiring and back up lights yet.
