werd,92turbo4life said:i did it a couple of times. i only biult up like 2 pounds of boost otherwise you will sit at the light and smoke your tires......
it is helpfull considering i took out an awd talon turbo
92turbo4life said:lol same^
but are trans are really strong because mine goes from 2 to 1 and i push it all the time. i love my strong ass trans
werd, stay below 2500rpm and your Good To Go! its nothing like a launch in a 5spd.Jetfixr757 said:Bear in mind, the stall speed on the torque converter is 2500rpm, that means to say, at or about 2500 the tires will start to break loose, so, you need to rev just under 2500 and hold it, then release at the green light, as in staging tree, like riding a bicycle, 1 foot down the other up, once you get the nack of the footwork, it is like a normal reaction. Then all you do is hang on for the ride.
William 89T
