Istalled yesterday my ATI damper, it is very nice product but there was minor fitment issue I want to share. After installation I couldn't turn engine by hand, found that outer edge of damper rests on the timing belt cover. I marked it with black marker on the first picture. Second picture is of the cover after 5 min of grinding, there is enough "meat" there to do it
http://img86.imageshack.us/img86/4734/atidamper04do1.jpg
http://img147.imageshack.us/img147/7241/atidamper05eg6.jpg
Damper OD where it interferes with cover is 172.5mm, it is larger than stock. Another solution would be to chamfer ~ 2mm from the damper. I hope I did not stress internals much and did not damage damper when tightened it against the cover
http://img209.imageshack.us/img209/3453/atidamper01da0.jpg
Damper at the piston 1 at TDC position
http://img98.imageshack.us/img98/861/atidamper06om0.jpg
http://img101.imageshack.us/img101/6096/atidamper07rk9.jpg
