ATF fluid for power steering?
MoreliaSpilota
20
Gainesville, FL
Bought myself some power steering fluid, went to pour it into the resevoir, until I saw ATF only. so, I can ONLY use ATF for the power steering?
This is completely new to me.
I stared at the thing for probably 5 minutes questioning why I have to put automatic transmission fluid into the power steering if I have a manual transmission. :biglaugh:
Just need a conformation that I should be using ATF instead of PS fluid. Thanks y'all.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Yes, under no circumstances should you use regular Power Steering Fluid in the system. You need to use ATF, so yes, it's okay.
nctexan
268
Houston
I know what the TSRM says...but would there be an exception for using a high performance product such as Royal Purple or Red Line PS fluid?
barkz
363
Afghanistan
would you put "high performance" PS fluid into your tranny? i would just stick with what it says. theres a reason for that
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
damn, the product marketing has really worked its magic on you.
Its the other way around. Atf in the ps.
