arp
utsupraguy1010
utah
Hey i got the arp head stud kit and need to know what they need to be torqued down to exactly the box has 3 different options for the 7/16 stud they are 53ftlbs, 60 or 63ftlbs, and 70ftlbs. Can anyone help i need to know asap
jdub
Feb 10, 2006
10,730
Valley of the Sun
7/16 studs? The 7M uses M12x1.25 threads for their studs. The latest spec sheet I've seen spec's torque at 80 ft/lbs using moly or 120 ft/lbs using motor oil for lube.
Sure you got the right studs?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Cale;1050513 said:
have read of some that has torqued to 90 also
Doing that would be incorrect and raise the value into the safety margin ARP designs for it's studs. Don't do it.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Adjuster has the earlier version of the studs installed...it's spec was 81 ft/lbs using moly -or- 105 ft/lbs using 30W motor oil.
Want to guess which lube he used?
BTW - the current spec is 80 ft/lbs using moly and 120 ft/lbs using 30W motor oil.
The reason for the difference between moly and oil is the friction reducing properties of moly...it allows for a much more accurate reading while producing the same clamping force sandwiching the HG between the block/head decks. One should always use moly if given a choice.
