ARP Rod bolt nuts
kotu100
1,899
Easton, Ma
hey guys, i cant find 2 of my ARP rod bolt nuts.
can i find replacements for these anywhere? or will i have to call ARP and get them direct.
kotu100
1,899
Easton, Ma
Will I be able to use grade 8 stainless nuts with no I'll effects. I have no problem
ordering em cuz I'm waitin for some other stuff anyway.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Moy;1570822 said:
I'd use the highest grade you can get honestly... can't be too safe when it comes to the rotating assembly :)
There's probably a good reason why ARP bolts/nuts cost 10x that of anything you get at a hardware store........in other words...why risk it, get replacements. Believe it or not, PROPER bolt/nut combos with just the right amount of torque are quite complex.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
+1 please don't get nuts from the hardware store... You're dealing with engine internals here, these things are under huge amounts of stress and having the proper torque on them is critical. Get the right nuts from ARP and use the proper lube and torque specs.
