ARP Head Studs
tte
Breaking In - in progress
Northern California
There is a long threaded end and a shorter threaded end on the stud.
The shorter end had a provision for a allen wrench so that end must be up.
The longer end goes into the block.
My question :
When installing the stud, does the longer threaded end completely engage into the block or will there be some thread on the stud exposed?
Cheers,
Roy
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
IIRC When i installed mine, theres was still afew threads above the deck surface, i chased all the threads numerous times, and they all went in the same depth
Roy: Be sure to chase all the threads with a tap then screw the studs in finger tight only.
There will be some exposed threads but this depends on Late or Early block just how many.
tte
Northern California
Hi Ian,
I did just that...my block is a 88 and I have some threads exposed when I hand tighten the studs in place.
Cheers,
Roy
lazarous
Walking Dead......
Jun 1, 2005
93
Portland, Oregon
same here, its nothing to worry about
measure how deep they are going and and make sure they are all the way in
if they're not all the way in, you won't be able to tighten the head down...
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
theres an hole on teh top of one of the studes big enough for a 5mm allen wrench this side is facing up the opposite side screws into the block.
