i am in the middle of a build and the short block is pretty much all taken care of. i have a few questions, first of all which size mhg should i go with? .012 was taken off the block and .010 was taken off of the head.
second question is, what is the difference between arp head studs and head bolts, which is better? the bolts seem to be a little bit cheaper, would i be safe to use them? my long term hp goal is probably around 400 most likely a little less though.
thanks for the help,
Zach
Zach
