arp head studs...check yours!!
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
ok, so i made a pst a while back about my car smoking and shit wondering if i blew my head gasket. well tonight i took the valve covers off and i was going to retorque them and see if they needed it....well WTF!!! a couple of them were at like freakin 24ft lbs!!!! i torqued it to 80ft lbs last xmas. and a coupler were still at 80 but i torqued them all to 85ft lbs now. so i will see if that helps anything...
I retorqued mine after 1000 km's and found a few not as tight as the rest.
Going by Cometic's info if new hardware has been used it should be checked after a few heat cycles, I've always done this out of paranoia but it was good to see it in writing.
empera
Authorized Vendor
Philly.
yea i've been meaning to re-torque mine, even tho i torque them at 95-100lbs, got me paranoid now...
malloynx
NC
hmmm, i thought studs were good to go.. i put mine at 100 ft lbs.. maybe this weekend i'll give them a check just to be sure
figgie
Twin Cities, Minnesot-ah
they are actually
see i never have to retorque mine.
why?
simple I FOLLOW the instructions of ARP and actually measure the stretch after three torque downs. It should be within the guidelines that ARP set. If not. Torque down 3 more times until proper stretch is acheived. This is the part that I have seen no one ever do.
Ummm up there in my last post I said you need to retorque only if you have "new" hardware so if you've done a trial assembly and backed the nuts right out I guess this would be considered used hardware.
Scenario 1: Brand new stud kit, install torue to spec then after some heat cycles retorque.
Scenario 2: Old stud kit, install torque to spec and forget.
Scenario 3: Brand new stud kit, install torque to spec and forget and have a few in the middle back off a touch and suffer another BHG and wonder why.
I'm not saying it's certain this will happen but it's small insurance to do a retorque for the added peace of mind.
figgie
oh no what I am saying is that ARP recommends to install and reinstall 3 times and then measure for stretch. It has to stretch otherwise the heat cycling will do it for you.
