Aristo Downpipe on Mk3 help!
OK I'm getting near done with swap and I need to someway come up with a downpipe.
Its a aristo 2jzgte I'm keeping the stock twins. These are the options that I have come up with.
(1) First would the aristo stock down pipe work with a little modification.
(2) or take a mk4 down pipe and cut off the falange and weld on a aristo falange.
(3) Order this http://store.driftmotion.com/static/i-driftmotionjza70downpipe.php and cut and weld on a aristo falange.
(4) order this http://cgi.ebay.com/Supra-JZA80-NON...r_Truck_Parts_Accessories&hash=item43a5d450c0 and just complete the test pipe with custompiping.
Question is wich one of these will work and what is my best choice.
Say if you have any better ideas
Links i have found.
http://www.supraforums.com/forum/showthread.php?568791-2jz-gte-downpipe-question
http://www.supramania.com/forums/archive/index.php/t-113083.html
Vrank!!!
hahahahaha
Dec 17, 2009
136
TX
Have you even tried to fit the downpipe it came with before you started asking questions?
Anything works with modification.
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
When I did my swap I couldnt find an aristo flange so I took that last cast piece and welded pipe straight to it about 6 inches with a 2 bolt flange, not the best idea but it worked well for the 6 months I had it. Then I fabricated my own down pipe.
Search on eBay for a 2jz decat mid pipe. Or make your own flange which wouldn't be too hard.
