Aristo 2JZGTE engine mounting (bracket) don't fit on mk3 crossmember mounting
SupraClaou
846
4
Athens,Greece
Guys...I prepared the aristo 2jz and was ready for installation.
I also hit the firewall a bit. But the engine's mounting won't fit! :aigo:
I need to push it towards the firewall about 1 inch,so I can come
over the crossemember's mounting.
The aristo's engine brackets are also a little spread out (wide open)
towards the member of the chassi.
Do I need to get the 1jz engine brackets for the correct mounting?
Kind think of anything else:1zhelp:
Need help guys...
Thanks,Klaountio
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
hottscennessey said:
Yes, you need JZA70 mounts. Assuming the '1990' in you profile is the correct year of your car.
He is right. The Stock Aristo or MkIV mounts will not work in a MKIII chasis. You will need to get the JZA70 mounts or one from BIC here on the forums to do the swap.
SupraClaou
846
4
Athens,Greece
My mk3 is 6/1990 year model.
I do have the 7M mounting insulators.
So...I need JZA70 engine brackets (mountings),and I will use the 7M's
rubber mountings...correct?
Nopaint
110
Jan 30, 2007
172
GA
so why do people use the 97 supra mounts when doing the 1J swap? I think I read that somewhere...
SupraClaou
846
4
Athens,Greece
How much $$ do the JZA70 mounting cost?
But to be hounest,I 've seen a 1jz engine with aftermarket custom mounts!!!!
Why the guy should do that,since he has a JZA70 mk3???
