are bosch platinum good sparkplugs?
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
Bosch makes horrible plugs just plain horrible go NGK or autolite coppers NGK #=2230 or 3330 Autolite#= 5503 turbo gap at .028 and N/A at i think .038 no too sure about the N/A one though look it up in the TSRM to make sure
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yea just take them in and tell em you got the wrong plugs they will exchange them
EDIT:: I use NGK 6097's
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
from my (limited) experience, bosch and japanese engines do not get along. I installed them by mistake in my maxima and they caused horrible stuttering problems during acceleration.
mk3713
Up for sale
Nov 29, 2005
97
Houston
Bosch plugs especially the platinum do not work good on our cars. You could install them and see hos it goes. Worst case scenarion on a turbo engine going lean is a melted ring.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
how does a plug cause a lean condition?
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
We often had DIY'rs that brought their Diamantes, Monteros etc into the shop complaining of poor idle, lousy driveablity etc after doing a tune up with Bosch Platinum plugs. 9 times out of 10 installing factory plugs would cure the problem. I don't understand the science (narrower insulator, higher resistance? etc) but there was always an inprovement when the factory plugs were used over the Bosch
DegreE
500
Memphis & Miami
I used Bosch Plat 4's in my 95 Eclipse RS on a 75 shot, they fouled out in 1 night.
After that I strictly use NGK's in all my cars.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
You shouldnt use platinum plugs on a turbo car, in most cases theyre too hot. You'll want to run NGK copper plugs (6097s)and gap them properly. These are the bkr7e model which is probably a perfect heat range for most turbo applications. NGK copper plugs <$2 and will last quite a while, even if they done theyre cheap to replace.
