i was fitting the engine in and i noticed the crank pulley hitting the lower sway bar. i'm thinking if i get the ATI pulley it would be ok. the unorthodox pulley would work,but i've heard not to use those
Looks like you didn't cut the mounts right. You either cut them to much or didn't cut them enough in the back. I really don't know because I cut mine but have a 1JZ and it is fine.
i got the mounts from BIC....but...someone else may have found the proble for me...he said that not having the tranny in there will make it lean forward. so once i get the tranny hooked up it should be fine. raising the front
