Anyone with a speedo cable sitting in their garage...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,238
Atlanta
If you happen to have a MkIII speedo cable sitting around, and you have the time:
Could you please measure it for me?
I'd like to know the exact length of the cable, as measured up to but not including- the connectors.
aka- the actual length of the black plastic covered cable sheath.
Thanks much.
Asterix
Lurker of Power
Vienna, VA
I'll check my stash this evening to see if I saved my old one. Which piece do you want - the short bottom piece or the longer upper piece? N/A or Turbo? Mine would be for an N/A.
Chaingun
285
Mooreland OK
I've got mine out to replace the end at the cluster( there an $8 kit at Autozone that works great for this) I can measure it for you if I need to it't the longer piece from an 87 turbo
Scot
Enough is Never Enough
Jan 9, 2008
185
Houston, TX
I just replaced mine.... if it the short one that connects to the tranny, you can get it at the dealer for about $20.... one of the only good deals there...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,238
Atlanta
I already have a new short one.
I'd like to know the size of the long one, and if I'm not mistaken, the turbo and na
long cables are the same part.
