Alrighty, if you guys didn't see the pictures of my garage and driveway, well then here ya go:
so, this is preventing me from doing my retorque.
Therefore, I am asking for some help from my fellow supra brethren!
I got some tools, and know what to do for the most part, just need a warm garage, as well as someone to help me figure out a couple problems.
Refer to my quote from the thread I posted in the mk3 section and got no help on:
I also need to figure out which code, 24 or 34, I'm getting and figure out what is causing my car to cut out under full throttle, around 4200 rpms in 4th, a little sooner in 3rd.
Okay!
First off,
I installed my new toyota master cylinder on Christmas day, and must have bumped something, my dash lights now don't light up.
Something to note is that it's not a stock cluster, it's probably an ebay type one, the one with the blue/green switch and dimmer control thing. I like it, but my buddy who owned the car before me, installed it and apparently broke the last one that was in there.
Any ideas on what I might have bumped? Possibly a fuse went out?
Something to add to this, which is probably related, is that my blinkers weren't flashing after this as well, but were coming on, then randomly started working a day after I finished my headgasket job. So, now they are working intermittingly, whether just blinking like a couple times, then stopping, or just not flashing but coming like they were before my headgasket job. Mostly though, they just won't work.
Now to the hood lever (or whatever you want the technical name to be, the hood release inside the cabin of the car.) issue. I went to pop my hood to check my codes yesterday, and it just kept coming out, and the cable came out of the little slot it sits in on the lever, and didn't pop the hood. Any solutions you can think of? Try taking apart the lower dash panel and investigate, or is it something around the release for the hood?
