anyone used these 550cc injectors?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
YoNkErS87t
streetside mechanic
In the Garage
Just got a set in myself and installed them yesterday. The fit coulndn't get any better. The o-rings that come with them are the ones you need to use.
I also have a friend that ordered the same injectors a month or so back from the same company and has no problems with them.
MKIIINA
Destroyer of Turbos
Plano, TX
i have been running these on my car for about 8 months now and couldnt be happier with them. check the sig for mods but really cant say anything bad about them
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
okay cool, some of you might have noticed that i posted this same topic on SF (best of both worlds) and i got replies from two people who used these injectors and installed them with the o rings which came with them, and they work fine. hopefully my car will be running by the end of the week.
Adjuster
That is a great deal. Injectors and clips for just over 300? Nice.
When you put your injectors into the motor, look at the body of each, and note that some flow slightly more than others.
Just because I'm picky, I put the higher flowing ones in #1 and #6 and then the lower flowing ones in the middle locations. I know they are within 1% and all, but we all know that #1 and #6 run hot, so why not send them 1% more fuel if you can? (Just seems like a good idea to me anyway.)
shaeff
Kurt is FTMFW x2!!!!
11
Around
i have these, too. lucas is considered to be of the best injectors made.
-shaeff
