Anyone used 680cc RX-7 Injectors?
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
I'm trying to figure out if '85 RX-7 injectors will work on the 7mgte. They're 680cc low-imp (PN 195500-0900, orange top) but I've been searching for a while and haven't seen any info on whether they'll fit the rail or injector clips (or where I can get clips if they're needed). The clips look to be type C (just judging from memory when I pulled my 22re injectors on my 4-Runner), I'm pretty sure the 7m are type E.
Any help would be greatly appreciated!
dok33
Apr 16, 2005
934
Austin, TX
starscream5000 said:
Do you know if they are top or side feed?
Top Feed:
getimage.php
Heres a shot of the connector:
getimage.php
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
well i just got 720s and i plan on running them on a 500 rwhp motor. i only have a map ecu, but after talking to an engine builder, he said i should have no problem with the 720s. i also would like to run e85, and thats why i have such a big injector!
dok33
Apr 16, 2005
934
Austin, TX
Don't know much about the MAP ECU, but I think it has an adjustment for inj size. E85 FTW, I'm running 12psi on my dd Escort with a 9.2:1 c/r and no intercooler :)
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
haha.... wow, escort maddness. and yes, the map ecu is a fuel tuning device. it converts the motor to map, and it allows tuning for different size anything dealing with fuel.
Silvermk2
MkII Weenie
Apr 4, 2005
99
Stockton, CA
They are actually 700cc at the standard 43psi. I was thinking of using them on my car, the problem is they are pretty expensive to buy from the RX7 guys. Typically they want about $120 for 2. So new RCs only are about $200 more by the time you get the old ones cleaned.
dok33
Apr 16, 2005
934
Austin, TX
Even better :) I've got a source where I can get them for a good price, just trying to figure out if they'll fit and where I can get some injector clips to hook 'em up. If it's going to be too much work I'll just go with RCs.
Silvermk2
MkII Weenie
Apr 4, 2005
99
Stockton, CA
I'm sure they'll fit fine. I use the later FC high imp 550s in my car now. The GSLSE 680s are a popular upgrade for the early FC guys. The clip is a standard injector clip I believe.
dok33
Apr 16, 2005
934
Austin, TX
Picked up 6 brand new (old stock) injectors off ebay for $240:biglaugh: Fuel system complete, now I just need a turbo to help me use all the fuel...
So by "standard" you mean I should be able to use any aftermarket clip like the ones RC sells for their injectors (type C connector I think)?
tte
Breaking In - in progress
Northern California
What brand were they?
Cheers,
Roy
dok33
Apr 16, 2005
934
Austin, TX
Answered my own question, forgot I had a set of Honda injectors with clips in my parts pile for my turbo 4runner project. Clips are type C and fit the RX7 injectors.
noah89t
get naked & boost a supra
these may help you
http://www.rotaryresurrection.com/rotary pages/injector folder/injector.html
you need to search on this site
what i found
84-85 13B NT low square center 680cc orange 195500-0900
86-87 13B NT low square center 460cc red 195500-1350
86-87 13B T low square center 550cc tan 195500-1370
88 13B NT high square offset 460cc purple 195500-1350
88 13b T high square offset 550cc purple 195500-1370
89-91 13B NT high oval center 460cc red 195500-2010
89-91 13B T high oval center 550cc purple 195500-2020
As a side note, replacement fuel injector clips(for wiring harness) can be obtained from auto parts stores to replace broken stock clips. I got the parts from autozone:
GP Sorenson part 800-9416 Fuel Injector Connector
