Anyone running the MAP ECU?
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Wanted to see who's all running on the MAP ECU I just purchased one and wanted to see if anyone had pictures of there install.
Also is the air temp sensor required mine didn't come with one.
BoostedFloto
154
Tampa, FL
1) do yourself a favor and buy the $150 fields harness to make it plug and play.... but IF YOU DONT the install isnt bad its about 7-9 wires.... but youll have to hack into your harness...
2) yes you need the IAT sensor, if you are planning on getting rid of your afm... they are about $35-40 bucks.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
I need the sensor too hook up like this but thanks for the help I'm going to look into the way the MAFT takes the IAT.
BoostedFloto
154
Tampa, FL
you just connect the iat sensor to the two wires for the afm iat sensor and youre done...then put it in your IC piping after the IC...
as for where to get one you can try powerhouseracing.com or mapecu.com
