Only problem with the idea is the gluster is shaped correctly for one way only. The steering column hump is to one side for the correct seating position ( rhd or lhd), the vents are also arranged correctly for one side only, and the dash flows with it, so if you put a rhd cluster in a lhd you're most likely gona have to cut the dash to flow with it, or possibly cut the cluster? I was under the assumption that you couldn't cut the digi clusters since it would break it or screw it up. good luck none-the-less!
eric
