Anyone mounted the Spearco IC?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
What do you need in the way of hardware/couplers/etc to install it? My hardpipes are built for the stock 89+ IC, so I rather doubt it's a direct bolt up. Among other things, the inlet and outlets point the wrong way...
IHI-RHC7
"The Boss"
Oregon
I dunno, we crammed a blitz 4 core in the stock location, and it worked out alright I suppose.
Do post install notes if you figure out all that's needed.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
all i needed was 2) 2.5" 90 ell sili couplers, but all my piping is 2.5 so if your using stock piping you will need some 2-2.5 reducers also.. as for mounting stuff, i made my own?
Mr. Y
80 miles away from Kremlin
to GrimJack:
Spearco IC is quite Plug-n-Play, but you'll need welder to fabricate mounting brackets.
Stock piping CAN be used with Spearco IC, but you'll need come adapters (I've made metal ones, but you just can temporary use piece of PVC pipe as adapter).
As for brackets - they are very simple. Just get some 3mm steel sheet and some tools - you will be able to fabricate your own without problems.
PS: my Spearco is mounted with stock oil coolers - all mounting brakets were fabricated without any probs using 3mm and 2mm steel.
PS2: I'm sorry, but I haven't camera to give you some pics. =(
