Anyone mount their AFM AFTER the BOV?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
After a quick test fit, it looks like I could replace my upper 3000 pipe before the throttle body with my Lex AFM, using some proper sized couplings. Anyone try this to eliminate the problems assosiated with venting BOV's to atmosphere? I figure it will get a bit hotter although I am running an under-headlight cold air intake plus I could wrap it with header wrap. Any feedback or potential setbacks I should know about before I try this? Will the AFM function properly and handle 20 psi? Is it 100% airtight? Thanks.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
ive seen pictures of some cars like this, i supose it might work but i wouldn't even try it with out a wide band to monitor the afr's constantly while in boost.
best of luck
lagged
1991 1JZ
new rochelle
i may be wrong, but i think this will only work if you can get the HAC to reference from wherever the AFM is located.
MKIIINA
Destroyer of Turbos
Plano, TX
id be concerned how the sensor would deal with elevated pressure levels and how correctly it would read. also if the sensor would snap off -> right into the block = no bueno
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Can you point me to a place with this price? I thought they were 500-600. My car is tuned and running perfectly with a SAFC2 but I am getting a fair bit of compressor surge with the bosch BOV and wanted to try venting to atmosphere. (without major changes)
rakkasan said:
Why not just go maft? a full maft set up can be had for $150ish and it wouldn't look like complete ass
