Does anyone have a problem with boost cut when its cold out? right now during the day its fine but at night when it gets colder it hits boost cut. my mods are 3in dp and blitz cat back.
gnarkill87;1237107 said:Does anyone have a problem with boost cut when its cold out? right now during the day its fine but at night when it gets colder it hits boost cut. my mods are 3in dp and blitz cat back.
Supracentral;1237111 said:It's not unusual to hit cut when it's cold if you are already close. Denser air means you need more fuel.
How much boost are you running? If you're running stock boost, you likely have a small boost leak.
gnarkill87;1237132 said:iam running stock boost, but it only does stock boost when its hot out, when its in the 40's and 50's iam hitting like 14, and colder it does 15+ and cuts out. how would a boost leak make me run more boost?
Stock actuators are 10 psi iirc.Supracentral;1237231 said:Could be a leaky wastegate diaphram, or the small hose that connects the wastegate to the turbo.
Factory boost is 6-7~ psi. What you are seeing is a lot of boost, even for a cold day. Is the wastegate shimmed?
What do you get in "warm" weather?
Supracentral;1237258 said:Tissimo, read the TSRM.
5.5 - 7.5 psi (Manual Trans)
4.8 - 6.0 psi (Auto Trans)
Free flowing exhaust, etc will raise it somewhat.
