Anyone ever tried an STS style turbo setup on an N/A ??
DGmk3
DomesticMan sucks
May 15, 2006
122
Superior WI/(Duluth MN)
I'm gonna do a rear mounted turbo setup this winter on my Audi ...no need for and intercooler or BOV and the turbo stays cooler. there's room under a supra for all the piping just a thought or is it stupid considering a full turbo kit is just a turbo car with a dead HG away
Tire Shredder
569
Oshawa
doesn't make much sense. that's a huge cost for really...no gains. those setups were designed for vechiles that did not have turbochargers in mind at all for their cars. In those cars there is no room in the enigne bay for a turbo and al lthe piping. Fortunatley, with supras they had turbos on them from the factory. replacement turbos, aftermarket ones and manifolds...piping kits are all readily available and competitivley cheap too....makes no sense to rededsign the entire turbo charger system of the car.
more ic pipes, water lines and oil lines is definatley not a benefit when there are so many other options.
supra90turbo
shaeff is FTMFW!
MA, 01440
Remote mounted turbo on a supra is just plain dumb.
You can get a stock turbo manifold for $30
I challenge you to do the same with an STS setup.
You'll need an oil pump, lines, and not to mention 12' of IC piping...
DGmk3
DomesticMan sucks
May 15, 2006
122
whatever it's just an idea to try something that else besides what every single person that builds an na/t does a friend of mine built one on a pickup for under $500 and it works good and has no issues so it can't be that retarded
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I disagree, that setup could work very well. A few extra feet of ic piping will make very little if any noticeable loss in response or power, and, in fact, the turbo will run cooler and intake temps will be lower. I have wanted to test it out for a while. Remember, there is no intercooler needed because the piping is in the air stream under the car and the turbo is already cooler. If you take that into consideration, along with a true cold air intake in the back, the piping is only a few feet longer then stock with less pressure drop from no intercooler. It could deffinately be done on a MK3, there is plenty of space under there. It could go where the huge stock muffler was.
Anything has got to be better then NA! :biglaugh:
supra90turbo
shaeff is FTMFW!
MA, 01440
aaron, you've got a point. anythings better than NA.. lol
IF your friend made the kit for under $500, then go for it. different isn't ALWAYS bad.
Chrisfrom1986
Unauthorized Lurker
Jun 10, 2006
85
Fresno
Hotter exhaust temps means better spool time am I correct? So moving the turbo into a cooler exhaust stream would actually decrease the amount of spooling power available... then there comes the fact that coolant and oil lines will need to be extended wherever you mount your turbo. The youll have to figure out who to get that oil and coolant back into the system... hmmm custom remote sump much? Plus the fact that Im sure it rains pretty bad where your from... so keeping that intake filter dry would take some creativness in itself... If you undertake this task, lets see the result.
The above may be totally false information so ignore me as you see fit.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
You don't need coolant going to it, it would not need cooling. You do have a point about the exhaust temp, but it would still get the same pressure and we are only talking about 5-7psi here so you don't need much to make that happen. As for oil you could get a oil filter sandwich adapter and route it like it was a cooler, but partially bypass it to get only enough oil pressure to keep the turbo happy.
csnow
Matthew 6:33
Palm Bay, FL
Doesn't cooler equate to denser? Wouldn't air that is denser spool a turbo faster? Maybe I am out to lunch with this logic...
89supturbo
186
Delmar, NY
i love this huge lack of real factual information regarding remote mount systems, lets just clear up a few things specifically regarding actual STS kits, first they still do require a BOV they also come with intercoolers which arent necessary but add quite a bit of power, as for oil they have in-line pumps that run to the turbo and theres no coolant in the turbos, spool time at least on V8's isn't an issue and about loosing boost u only drop about 1-2 psi through the system which isnt bad considering the stock supra intercooler drops 3.5
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
In response to the problem of water in your intake, they designed a special cover for the intakes on the STS's that are waterproof and breathable that you slip over it come winter time. Kinda sounds like gore tex.
I think the idea sounds pretty cool IMO.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
yeah but anything like that seems like its going to get rid of a Lot of breathing ability. i say redesign the intake placement.
