it's a tool of sorts meant for lighting fires....it's basically a hand operated "thing" that uses compression to ignite a tinder such as "char cloth"....it works like a diesel motor compressing air which in turn heats the air to really effing hot temps....so basically it's a cylinder with a plunger....you put the tinder on the end of the plunger, place plunger in the cylinder, then smack it like it owes you money and hopefully when you pull the plunger out you'll have a glowing ember...
Just wondering if anyone has ever seen one or heard of such a thing....
I ask cause I made one tonight at work on the lathe....can't believe it actually works...my hand is sore now though....I'll post pics later when I get home.
