Anyone elses car hard to start in the cold?
SupraMario
I think it was the google
The Farm
I drove my car yesterday, well tonight its like 30 outside and she wont start.
ive still got summer oil in here, but she cranks over just doesnt start. any suggestions?
gixxer750
2jzget comingsoon!
Mississippi
hmmm sounds like you've got a problem somewhere. Mine cranks up and idles fine. It cranked and ran perfect when it was 21 degrees this morning. It idles about 500 for a little while, then the idle comes up to my set 900rpm. I have no cold start injector, or ISC....
Dirgle
Conjurer of Boost
Pauma Valley, CA
Mine started fine in 10 below. She stumbled for a few seconds and then figured out that she needed to raise the idle. Use the TSRM and see if your cold start injector is working. It might also be your temp sender. The ECU might not know its cold out.
mkiii222
Troy, MI
Mine will hesitate a little, maybe have to crank for an extra second or two. But as soon as she catches she'll idle up to about 1200, and once she's warm she runs better than in the summer.
I've just started having some trouble starting it now that it's finally getting cold here. I keep having to get the broom to hit the starter with...
Yesterday night a rat or something climbed into the engine bay and ate my #1 spark plug wire :mad: Luckily I had an extra, but if it happens again I'm going to be really mad.
mkIIIman089
Ohio
I've been fine in 17* so far and I run 20W-50 so I don't think thats the problem; same cranking fired straight to 1500 RPM and then dropped down slowly.
Could be CSI... I'm assuming you checked for codes?
Cedrock15
The Sarcasm Specialist
Sep 29, 2005
126
Bucks County, PA
those honda guys will try to sabotage our cars anyway possible.
SupraMario
The Farm
havent tried to start it yet. i just figured it was the cold im going to mess with it this sunday. see whats up.
