Anyone drill a hole in the head above cylin #6?
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Okay.
So I've got my head off right now fixing the BHG, and I was talking to whenmunkysfly tonight.
He had noticed that above cylinder number 6, there is a hole in the block and gasket, but not one in the head. Check attachment with circled hole at the top of the picture for reference.
Has anyone drilled that hole in the head and had any problems? You would think it would help cool that cylinder better, especially seeing as most BHG's are in #6...
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Yeah, If you want to get heat away from the combustion chambers, iron conducts heat better than air, so i don't know why the hell someone would drill into the deck!!!!
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Yarden,
you forget that I don't know much about engines.
Explanation in dumbed down terms?
CBLEGUY
Organic90T "Growin Roots"
Nov 24, 2006
127
Cape Coral, Florida
My 90 has the same thing but reversed. the head has a port in the back next to #6, but the block does not. The gasket also has this port. I think it was an afterthought or something.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Woah... so this opens up a coolant passage!
Kyle, does the hole go all the way through into the coolant passages? In the picture i thought it looked like the bottom was metal, not open. Is there a matching hole in the head?
I might have to do this one... :)
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
I think that there is a hole in the block, I need to double check, it was late last night, but there is a matching one in the head.
MKIIINA, how long has your brother been running it like that and what kind of HG did he use ect ect?
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
ok guys i read up on it alot a long time ago and from what i read(and by drilling out my own head) there is a passage about 10mm down into that head by drilling down to this you get more water flow to the back of the head where most of your BHG's come from there are more holes the you can drill out as well on the intake side of the head but i desided not to do them because i thought it would affect the flow on the exaust side too much.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
hummmmmmm i found out some thing intresting about this hole drill hole thing
it's there to incresh heat in the egr to be more clean burning?
the ture case to this is does jdm head have the hole
cause toyota made 3 diffent casting's of the head
this may just be it or not i herd they made 2 diffent jdm casting's but i have no pruff of this being ture cetp here say from some peoepl off sea's
MKIIINA
Destroyer of Turbos
Plano, TX
he has been running it for over a year now with no ill effects. 1.2MM HKS MHG/ ARPs @ 90ft/lbs. Hes running about 10 psi of boost through a hybrid turbo at around 315-320rwhp.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
did japan care any thign for emisson's at all just woundering cause this si the onlt thgin i cna think of whay they whould do this in less drilling that spot whould lower the persures in other ares in the head/block and kidna bye pass the others
i think it has to do some thgin wiht eh egr heatign up the cyc to burn exases gases but hummmmm
whenmunkysfly
Jun 26, 2006
746
United States
Boostedstr8six said:
First time I've heard of this...
Anyone have any pics of a drilled out head?
Remember, the thing bolted to the back of the USDM head is called an EGR cooler.
i would have taken a pic but my head is bolted back up now.
Doward
4,245
Alachua, FL
I'm sure it has something to do with the EGR cooler on the back, yeah... maybe a little extra heat, to ensure it doesn't cool too much, would be my guess. Keep the carbon from forming in it and blocking it up!
