anybody have cams?
Properly degreed and installed the sound won't change. The difference is marginal on a stock car, but will make a large difference on a heavily modified one...
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
You'll change your powerband. You'll hold boost til redline and pull hard the whole way through.
But as stated, they will benefit more with other supporting mods and of course a good breathing engine.
Doward
4,245
Alachua, FL
Why yes, I have two.
lol, seriously though - stock exhaust with cams is a no. You need to beef up the intake and exhaust, before worrying about how much airflow the camshafts are directing through the head. (exhaust includes from the head to the turbo, btw)
boosthard
booster
May 19, 2007
101
las vegas nevada
so if i put different cams in my 89 auto turbo with bic ddp 3 in. test pipe hks drager exhaust and an apexi cai i would get better sound and performance?
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Please dont take this the wrong way, but cams for "sound" is stupid.
Cams need to be matched with the rest of the combo. Turbo, style of intake manifold, head flow, compression, torque converter (if auto) etc. If you're staying close to stock, cams are probably a wast of money as you'll probably see more hp/$$ elsewhere.
they're somewhere in the 10% area of improvement IIRC (like if you put them on a stock engine you might see 20HP to the wheels, but on a 500HP engine you'll see 50HP more)
bang for the buck they're useless, and like I said, they won't chang ethe sound of the engine much (if at all) if properly installed and tuned.
Keep in mind people have made big power on stock cams (well over 500HP)
boosthard
booster
May 19, 2007
101
las vegas nevada
ya that is true thanx guys
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
UHOH wheres IJ when we need him lol
Cams will like said before effect the whole powerband
Before cams I would get a better manifold, upgraded turbo, dp, and exhaust, oh and intake.... Then you may see a benefit..
AJ'S 88NA
2,419
Florida
I agree with most, unless you make other improvements they won't make to much difference. You have to get it to flow better to take advantage of any gain. And have some way of tuning, without it you will probably run worse than you did, I know from experience on that note. I did all the mods and still couldn't get it to run right without the ability to tune. Don't know if a turbo would be different.
big idealist
drifter at heart
Oct 23, 2006
135
lowry city, missouri
ok since we are on the subject on more flow i figured id throw this in here as well... how much would it be to completely port and polish the head?? cuz i have no idea but would like to know. oh and what kinda power expectancy??
AJ'S 88NA
2,419
Florida
One of our vendors has a post on P&P heads. As far as how much you could expect to gain, depends on what other mods you have to go with it like any thing else you bolt on these little 6 bangers. I've been told there is a lot of power to be had in the 7M heads by several "old school mechanics". It's very hard to put exact nos. on a mod which is why vendors always say "it depends on what else you have" Or "depends on what kind of tuning you do"..
Slow66
Apr 3, 2005
1,457
Newington, CT
Too vague.
There are several levels of "porting and polishing". It varies from a basic gasket-match and bowl blend, to completely reshaping the whole port for maximum flow.
The degree of porting should coincide with the rest of your modifications and the intended use of the vehicle....
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well from my under standing cams make the 7m mean but you need supporters to help add the gain from lager lift and slight lager duration
but if you have mostly stock head na cams may be a good idea
i ran them in both of my supra's and find the na cam to be much better for my driveing style plus they pull better to red line still drops off but not as bad
oh yae there is gain power as well
