any one used a RPS flywheel?
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
my clutch(r154) has been slipping lately under boost so i pulled the tranny to find out why. the clutch is a action stage 3 from driftmotion and has about 3000 miles on it. i know it should not be slipping with only 3k miles so i tried to adjust the freeplay and i was out of adjustment room! i goolged and found this thread http://www.supramania.com/forums/archive/index.php/t-579.html and it says that the rps flywheel is shorter than a factory flywheel which moves the clutch fork closer to the the slave, hence me not having any more room to adjust. is this true about the rps flywheel? my flywheel is also warped which sucks... so anyone with input on RPS flywheels?
